Sponsored by: CARiD
Headlights are always on
Old Oct 24, 2010 | 01:38 PM
mattslightning's Avatar
Default Headlights are always on
Guys my headlights are always on. It could be noon and the sun shining like crazy and the lights will be on. Any ideas? Its on a 02 Z28
Old Oct 24, 2010 | 01:43 PM
the_merv's Avatar
Take the Radio out and find the Photo Sensor for the lights..clip it and connect the wires.
Old Oct 24, 2010 | 08:30 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
https://ls1tech.com/forums/2743521-post6.html
Old Oct 25, 2010 | 03:55 AM
myk's Avatar
myk
I have a feeling he wants to fix the actual problem, not just go around it...
Old Oct 25, 2010 | 08:30 AM
the_merv's Avatar
It is a fix...take all the extra junk out to where you can control it on your own.
Old Oct 25, 2010 | 08:43 AM
Mike454SS's Avatar
It sounds like you've got a bad photo (light) sensor (it's in the dash in the center defrost vent), or something wrong with the DRL module that is behind the stereo.
Personally, I disabled mine because I don't like the car telling me when the headlights will be on or not, and I'm so used to driving older cars without auto headlights anyways, but if you want to fix it, first I'd try to swap that light sensor out, and if that doesn't work, then I'd swap the DRL module out.
Old Oct 25, 2010 | 09:21 AM
the_merv's Avatar
DRL's just control the Marker Lights I thought..
Old Oct 25, 2010 | 01:20 PM
Thanks guys. I'm going to try replacing the light sensor first.
Old Oct 25, 2010 | 01:54 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Check to make sure that photo sensor is still plugged in...If I recall correctly, just unplugging it without a jumper in its place will have the lights on all the time.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Oct 25, 2010 | 01:57 PM
Slamdsdime's Avatar
x2
In my S10, we cut out the photo sensor, replaced it with the proper resistor, and bam, off the lights went. With the DRL disabled on my truck, I still had the "Always On" feature, which puts the headlights on regardless of sunlight whenever the ignition sees power. Unplugging the sensor and puttin in the resistor fixed it. I'm sure, with my truck being a 99, that F-Bodies are similar.
Old Oct 25, 2010 | 08:33 PM
Mike454SS's Avatar
DRL module sorta is the auto headlight module. When it's daytime, it turns on the bright filament in the amber lights (the bright one is actually the turn signal/hazard filament, the marker lights use the dim filament) and when it's dark out, it turns that off, and turns on the headlight and parking light circuits just like the headlight switch would. When you have the e-brake set before you start the car, the DRL module will leave all of those circuits off. It has no ability to prevent the headlight switch from running the circuits the old fashioned way though...this applies to the Camaro, I don't think the Firebirds do auto headlights.
I'm not sure if clicking the e-brake up one notch after starting the car will shut the lights back off...I can't remember...mine actually worked perfectly fine when I disabled it, I just didn't like it...mostly because in EVERY GM I've seen that does the bright amber filament/DRL deal...the marker light sockets look burned...like they're not intended/rated for that much constant heat, but GM just did it anyways...so I disabled mine by opening up the DRL module and jumping the correct pin to ground with a little solder...if you make it see ground on the proper pin, it's the same effect as having the e-brake up 1 click when you start the car, except it doesn't affect the behavior of the red brake light on the dash, so that isn't on unless you actually meant to set the e-brake.
There's a reason you can't just unplug the DRL module...turn signals don't work anymore if you do or something like that.
