UUGGGHHH Window not moving!!
It did not do anything odd on the way down so I do not know what it could be? Since it is not making any noises is it likely a switch issue or bad motor? I was going to pull the window up but it was down in the door pretty tight so I decided best not to make it worse. Any ideas on what it could be? I assume it would not be a fuse because that would affect both windows?
Anyone replace one of these before? It looks like the little panel with the controls for the locks, windows and mirrors would just pop off and you would then just have to unhook the power from the window switch, pull off the old one and put on the new one and remount? No need to take the door panel off I hope?
Any info would be appreciated!!
Would a window regulator cause this? If the regulator was bad I would hear the motot turning right?
ANyone know of a guide for removing the door panel? I checked it out and there are some screws here and there but some instructions would be nice if anyone has seen any?
http://shbox.com/page/windowmotor.html
For those of you that have done it, does this seem a good way to go about it?
The window went down and just never came up, no noise when you push the button. I have looked online and people claim that symptom could be either. Anyone here have a more thorough answer to help me out on identifying which it is?
It's really not as hard as it looks. The hardest part is
locating the rivets. It helps to print the picture out.
Good luck man.
But....about 4 years ago my window stopped and was stuck down. After you get the panel off, take a hammer and smack the spot on the door where the motor is. I did that and it came alive and worked for another 4 years. I know you have a new motor and want to probably just change it anyway....but if it does start to move at least you can get it all the way up...which is where you want to have it to change the motor out easier.
Body shop replaced motor and I am good to go.
Thanks guys!
