Sponsored by: CARiD
New air lid
Old Jan 10, 2011 | 09:19 PM
mo99z28's Avatar
Exclamation New air lid
So i just put the SLP air lid on my 99 z28 and since then my car does not want to shift into 3rd gear i know the MAF links to trany. So do i need to retune my cpu or is my MAF shot and i need a new one.
trouble shot; connections, fuse, trany fluid, oil change.
P.S. car has been on park status for six months due to recent deployment although it was started for 30 mins at least twice a week, has new oil, new fuel and injector cleaner.
PLEASE HELP
Old Jan 10, 2011 | 10:30 PM
joshp14's Avatar
Simply putting on an air lid will not cause the trans to not shift to third. If you dont believe me, put your old one back on and I bet it'll do the same thing. Perhaps the element in the MAF may have been damaged. Is your SES light on?
Old Jan 10, 2011 | 10:32 PM
mo99z28's Avatar
no light on at all... so dont know what to do...
Old Jan 10, 2011 | 10:44 PM
Phstratton's Avatar
Might wanna check the fluid in the tranny. Could have a leak...who knows?
Old Jan 10, 2011 | 11:00 PM
mo99z28's Avatar
checked out the trany fluid its good im just not sure if my MAF sensor is shot or if i need to tune my on board cpu...
Old Jan 10, 2011 | 11:17 PM
Phstratton's Avatar
You're not gonna have to tune your PCM just cause you did an ls1 lid mod. I'd say chances are it's your MAF. Mine didn't trip a light when it first started going out.
Old Jan 11, 2011 | 12:00 AM
mo99z28's Avatar
and will the MAF sensor cause my trany to not shift from 2nd to third on low rpm?
Old Jan 11, 2011 | 08:31 AM
wssix99's Avatar
Save the manuals!
Is this a manual transmission? If so, the MAF has nothing to do with the transmission because... its a manual and YOU control it.
I wonder if this is some sort of skip shift malfunction?
Old Jan 11, 2011 | 09:35 AM
Joshu's Avatar
Like with everyone else, I HIGHLY doubt the problem is with your intake or MAF.
Old Jan 11, 2011 | 12:09 PM
mo99z28's Avatar
It is an automatic and from what i understand it the MAF sensor is linked to the transmission and it has been doing this after i installed the new air lid. Does any one know what oam resistance the MAF sensor needs to be to function properly?
Old Jan 11, 2011 | 02:58 PM
wssix99's Avatar
Save the manuals!
Can you post a pic of your install on the lid? The MAF shouldn't have been touched, but the air temperature sensor would have. Do you have it back in?
Old Jan 11, 2011 | 04:17 PM
KevinR's Avatar
Pic didn't work.
Old Jan 11, 2011 | 05:03 PM
1 FMF's Avatar
forgive me for asking, but how do you know the MAF links to the tranny?
Old Jan 11, 2011 | 05:07 PM
jsteele90's Avatar
i know if the maf is going bad it will throw a code and make the tranny shift incredibly hard because it increases the line pressure a shitton. as far as not shifting never had that problem.
Old Jan 11, 2011 | 08:48 PM
mo99z28's Avatar
read about it in a book not tryin to be a smart *** but thats pretty much what it said as far as chevys go.
Old Jan 11, 2011 | 10:13 PM
1 FMF's Avatar
do you remember the book? it makes no mention of it in my service manual and i would like to know more about it.
Old Jan 12, 2011 | 12:18 AM
need4fun2469's Avatar
could it be possable that since your car had been sitting for 6mo that the seals are dried out? I had a friend that had the same problem is why I'm asking. He only has 1st and 2nd gears.
Old Jan 14, 2011 | 10:32 PM
mo99z28's Avatar
Thanks for the responses but I ended up taking my car to a transmission specialist and it was the seals and a couple of other things so its getting fixed now with a couple of upgrades....
