Sponsored by: CARiD
part# for the rubber wiper bumper
Old Feb 3, 2011 | 10:00 AM
bob320fa's Avatar
Default part# for the rubber wiper bumper
Does anyone know the part number for the rubber bumper that the wiper arm rests against? Or even the technical term for it. Any assistance would be appreciated.
Old Feb 4, 2011 | 03:45 AM
Elthesh's Avatar
I don't know the part number, but I do know that there are two different sizes. The driver side is the larger of the two. Using the incorrect size on either side will cause the wipers to smack against either other when they are closed. At a quick glance, they both look the same, same design, but comparing them, they are quite different in size. So, make sure you get the right one for the right side. I picked up a couple at the junkyard to replace mine. They also stand on end, not on their side. On their side, the blades mostly don't contact them and slide right over em. Keep that in mind.
Old Feb 4, 2011 | 05:59 AM
eseibel67's Avatar
I was about to replace a missing one, and I accidentally found it laying on the metal shelf behind the strut tower. Might be worth a look.
Old Feb 4, 2011 | 08:45 PM
bob320fa's Avatar
Seems a hunk of ice took mine with it. Anyone else know the part number.
Old Feb 4, 2011 | 09:12 PM
PontiacFan's Avatar
I just went thru the parts file pdf & it shows them as 'part of air inlet screen'.
So you can not buy them seperately as GM part numbers.
Best bet is to find a local salvage yard & ask them.
Or email/call some of the other salvage yards.
There are a couple who are LS1Tech sponsor who may be able to help.
#8, part of #10-10299673
#25, part of #24-10246203
For example;
http://www.hawksthirdgenparts.com/93...passenger.aspx
Old Feb 4, 2011 | 11:00 PM
joshp14's Avatar
Thats correct, my TA is missing the drivers side and you have to get the entire plastic cowl assembly. As said above, try a salvage yard.
Old Feb 5, 2011 | 12:23 PM
bob320fa's Avatar
Damn...nothing is ever easy. Crazy how you can't pick up a "part" you have to get the whole "assembly"
Old Feb 5, 2011 | 12:54 PM
O2Form's Avatar
I have a set if you need them.......infact I have two sets of those rubbers. I pull um off! so the wipers can be adjusted down farther.
