Help with dead spot
Hoping one of those takes care of the problem. Other than that I'm not sure what would b causing it. I'm assuming fuel or ignition. Thanks for the help.
Car has SLP Lid which needs to be replaced. Previous owner dropped something on it and broke it. Now thes a big retabgular hole cut in the front of it. And that's the only mod it has.
I'm goin to out some fuel injector cleaner in it tonight also. Thanks again.
SeaFoam is great for the fuel system. I do it every 3-4 months as maintenance. But you should change the fuel filter after that tank of gas runs out......in case any dirt was loosened and went into the fuel filter. Its a 5 minute job and $12.00.
You should go work for seafoam. Trending Topics
Tell me you really do understand that process......you can't be that ****** airheaded edit..........
Pitch em on the GPS locator too.
Are you a salesman? Seriously. Talk about digging a hole.........you must read and comprehend....comprehending being the important part.
Put the shovel down.
Hose? It looks molded to me. I'm assuming the dealer would carry it or at least order it for me. I think Imma do my header install this weekend so everything is Gettin replaced. Plugs, wires, fuel filter, pullin off the AIR and plugging the EGR. so hopefully that dead spot will be dead Muahahaha.
Or you can get used factory lines "usually" at http://www.tacreationsusa.com/
He has a ton of good used stuff at good prices.
