Sponsored by: CARiD
Idle Question?
Old Feb 23, 2011 | 02:00 PM
alexus6798's Avatar
Default Idle Question?
When I drive my car, it runs great, but whenever I stop for a red light or stop signs, it idles at 1000 rpms for a couple seconds, then it goes to normal. Is this normal, or what could it be?
Old Feb 23, 2011 | 02:29 PM
alexus6798's Avatar
t t t
Old Feb 23, 2011 | 03:17 PM
KevinR's Avatar
Maybe IAC? Kinda what it sounds like
Old Feb 23, 2011 | 03:42 PM
alexus6798's Avatar
where is that located on engine and how can i check it?
Old Feb 23, 2011 | 04:09 PM
KevinR's Avatar
Here you go.
https://ls1tech.com/forums/generatio...high-idle.html
Old Feb 25, 2011 | 05:19 PM
alexus6798's Avatar
thanks for the help
Old Feb 25, 2011 | 05:43 PM
jim ravencraft's Avatar
HI.
THE ABOVE QUOTES ARE POSSIBLE AND ACCURATE!!!!!!
HOWEVER, OTHER CONSIDERATION COMES INTO PLAY:
BUMP STOP/ TPS
VACUUM LEAK
ENLARGED HOLE THROTTLE BLADE
THROTTLE CABLE ADJUSTMENT
IAC /MEASURE RESISTANCE TERMINALS A/B THEN C/D READINGS 40-80 OHMS.
TERMINALS READ:
D
C
B
A
GOOD LUCK AND GOD BLESS YOU AND YOUR FAMILY...........
CAPTAIN JIM
Old Feb 25, 2011 | 05:57 PM
alexus6798's Avatar
Originally Posted by jim ravencraft
HI.
BUMP STOP/ TPS
VACUUM LEAK
TERMINALS READ:
D
C
B
A
CAPTAIN JIM
Thanks, looks like I need to get to a shop and get it checked out
Old Feb 25, 2011 | 06:32 PM
Hi,
check throttle cable first.........you can do it!!!!!!!!check plastic square housing on cable near oil dip stick.....volt meter set to ohms and get readings....
Throttle blade hole 5/16-5/32 any larger more air than you need for stock cam.
Check cable at intake/tb manually move it. I used an additional small spring to pull my cable and increase throttle pressure..tps/iac two screw in each one.
Give them a good cleaning and reinstall. Perhaps cures problems for you.
Vacuum test is easy and tells you alot about engine....lastly a tuner can adjust for you if all is ok........let me know jim
PS: LOANER TOOLS AVAILABLE OREILLY/AUTOZONE PLUS ONLINE REPAIR MANUAL.
File Type: pdf
File Type: pdf
File Type: doc
