Help!!! P2101, p1516 on TBSS
iam only on boltons and I have trouble with these codes p2101 p1516
(TAC) module position sensor performance it all comes out 2 be the throttle body so I went out 2 change it. Trouble did not go away! Now I can drive out anywhere everything works fine expect on WOT get a reduce power engine & and engine goes out!
Any help will be great and will be apriciated so chim in guys thank u!
straight from gm service information
Subject: SES Light, Idle Surge, and/or Reduced Engine Power Mode with DTCs P0068, P0121, P0506, P0507, P1516, P2101, P2119, and/or P2176 - Clean Throttle Body and Perform Idle Learn Reset
Models: 2007 Buick Rainier
2007-2009 Cadillac CTS-V, Escalade
2008-2009 Chevrolet Colorado
2006-2009 Chevrolet Avalanche, Corvette, Express, Impala, Monte Carlo, Silverado, Suburban, Tahoe, Trail Blazer
2008-2009 GMC Canyon
2006-2009 GMC Envoy, Savana, Sierra, Yukon
2007-2008 Hummer H2
2008-2009 Hummer H3
2007-2008 Pontiac Grand Prix
2008-2009 Pontiac G8
2006-2009 Saab 97x
With a V8 Engine
This PI was superseded to update model years and add information concerning idle surge, reduced engine power mode, and/or DTCs P0068, P0121, P1516, P2101, P2119, and/or P2176 that may be experienced on high mileage vehicles. Please discard PIP4578.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
As carbon builds up in the throttle body of a high mileage vehicle, the ECM/PCM learns to compensate by increasing the throttle plate angle.
If enough carbon builds up, an idle surge, deceleration surge, tip-in hesitation, reduced engine power mode, and/or DTCs P0068, P0121, P1516, P2101, P2119, and/or P2176 may be experienced on high mileage vehicles.
If the throttle body is cleaned without performing an "idle learn reset/reset idle learn" with the Tech 2, the ECM/PCM may continue to compensate for previous carbon build up, causing it to return with a similar concern as well as DTCs P0121, P0506, and/or P0507.
In a similar fashion, if the ECM/PCM of a high mileage vehicle is replaced and/or reprogrammed without performing the Throttle/Idle Learn outlined in SI, the ECM/PCM may no longer compensate for existing carbon build up in the throttle body, causing it to return with a similar concern as well as DTCs P0121, P0506, and/or P0507.
Recommendation/Instructions:
If SI diagnosis does not isolate the cause of this concern, inspect the throttle body bore and plate for obvious carbon build up.
If carbon is present, follow the Throttle Body Cleaning Procedure in SI to clean the throttle body.
After ensuring that the throttle body bore and plate are clean, perform an "idle learn reset/reset idle learn" with the Tech 2 and re-evaluate the concern.
Notice: Depending on the vehicle you are working on, the "idle learn reset/reset idle learn" is normally found on the Tech 2 ECM menu for Module Set Up or Special Functions/TAC System.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© 2011 General Motors. All rights reserved.
2007-2008 Hummer H2
2008-2009 Hummer H3
2006-2009 Saab 97x
With a V8 Engine
Condition/Concern:
Check terminal tension at throttle body connector. If its ok, then the p1516 is usually a throttle body.
Also, whenever you clean OR replace the throttle body, you must perform a idle reset. Otherwise, the minimum learned airflow value stays the same with the new or clean throttle body and can cause problems.
