camaro wont start
camaro wont start
ok i was driving down the road and i was doing about 45 when the car started to buck i pulled over assuming the trans was slipping turn the car off checked the fluid everything was good so i drove it home everything was fine got to the house parked waited 30mins and tried to crank it again and it wont star everything turns over just wont start im getting codes
p0118,p0161,p0332
1999 camaro z28 a4 152000miles
p0118,p0161,p0332
Seems likely that the connector at the temp sensor maybe pinched damaged. The temp sensor itself could be bad.
If this checks out, look into the knock sensor.
Most likely a bad connection at temp sensor or a bad sensor is tripping up the knock sensor and oxygen sensor code.
