Finding a AC leak
I am, screw OEM in this case.
Sucks ***, this is going to be some work. . . .
Really crappy since it's such a new vehicle too.
How would you test the new one before installing it in?
The sniffer seems not to be as accurate as I want. I found the die first.
So what else should I do with the system?
So far, I want to replace the evap and the drier. The compressor seems to be okay, no other spots at all with the die anywhere.
Should I leave the die in the system? If not, yet again. How/should can I flush it out?
I think the orifice tube is okay to leave alone since the compressor did not come apart as I first thought.
