Where can I find these parts?
I got water in my PCM and I need to replace the PCM, Gaskets, and Pin Connectors. I went to 2 different dealerships, Autozone, and NAPA auto parts but no one carries these parts.. Does anyone sell them online? I need 2 orange PCM seals and a few of those PIN Female Connectors.
GM dealers have a large assortment of the pins. Unless you have a pin part number then I doubt you will get much help from anyone unless you know a tech thats willing to go thru all 27 trays looking for your correct pins.
You might give these guys a try
http://www.speartech.com/
They build harnesses for doing bench reprogramming so maybe they can sell you the parts you need.
Save the manuals!
Check out this thread. You'll need to go to the dealer to get the seal kit: https://ls1tech.com/forums/general-m...onnectors.html
The dealer should also have pins for you. If not, you can order them from Mouser Electronics. The catch is finding out the correct part number - will take a little searching but not impossible.
