what tool did you guys use to get the torx
what tools/bits did you use when you guys removed the idler pulley on the ac belt, i was replacing all my belts and pulleys and the one has a torx bit head, and i cannot find a bit to remove it, im sorry if im not clear enough but im trying the best i can to explain it
It's T50 torx.
it's really tight... I gave the bolt head a sharp rap using a hammer on the end of a 3/8"x10" extension, and then I was able to twist it loose with the T50 bit on a breaker bar.
i tryed it but it stripped the screw a tad, should i try again? that is the exact bit my uncle had that i used, is it reverse threaded? or do i just need to hammer the thing into the bolt/screw thing?
thanks for all the responses![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
i thought i had the wrong one, but seems like i have the right one![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
sorry for the double post
1 Post
Just make sure you stablize the torx on the bolt so it doesnt strip. Your going to want to put a pipe or something to extend the ratched to get more torque, or hit it with a hammer or something
yea i used a breaker bar when i tried last night, i had it in the bolt the best i could and i striped it a bit
i really am debating taking it to a shop local to me, i already have the pully but i KNOW they are gonna charge a few hundred bucks
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
![Barf](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_barf.gif)
that is exactly what i was thinking i should do
, but from under the car i couldnt get a good angle, so ill jack it back up and try again maybe today or tomorrow,
thanks for all the tips
well i found out that the reason the car was squeaking was because valvoline put on the wrong f'ing belt, so the replaced it. alls good with the world, right? NO they didnt put they rubber boot to the thottle body all the way on so i had a vacum leak, and the boot wont go back on....... f'ing dumb ***'s def. gonna do my own maintence from now on ![MAD](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_mad.gif)
