Sponsored by: CARiD
security light
Old Mar 24, 2011 | 11:05 AM
draggz28's Avatar
Default security light
alright its been 2 months since i bought my 99 z28 and ever since i bought it it has shad the yellow security light on what has to be done to take it off and why is it on???
Old Mar 24, 2011 | 11:07 AM
SSdreamz's Avatar
first things first, get the car scanned and let us know what code it reads, then we will be btter informed to help you out. what mods does the car have? has it ever been tuned?
Old Mar 24, 2011 | 12:13 PM
The Mighty Texan's Avatar
Security light or ses light?
Old Mar 28, 2011 | 01:05 PM
smg267's Avatar
VATS System. Vehicle Anti Theft System. You are on borrowed time before the car stops recognizing the key and will not start. You can try cleaning the pick ups on the key.
I would suggest trying the spare key or searching for the "Vats bypass"
Old Apr 4, 2011 | 06:54 PM
shepss217's Avatar
mine just starting doing this today too, i tried my spare key and it didn't help, i had my ecu tuned by frost and i thought the VAT's was supposed to be deleted? don't know what to do, my wifes grand am went thru this too and it only got worse, i tried doing the bypass and now the light just stays on too
Old Apr 5, 2011 | 05:10 PM
Frost's Avatar
VATS delete is for SWAPS with no BCM's.... I can't program out the fact that the BCM is not seeing the resistive pellet in your key and dis-allowing the starter because it's not in the PCM at all.
Old Apr 5, 2011 | 11:24 PM
shepss217's Avatar
ok, i have a new ignition lock cylinder on the way, from what i read that,s usually the problem, i tried my spare key and the light is still on
Old May 10, 2011 | 02:49 AM
knight2169's Avatar
did the new lock cylinder fixed the problem? Wanting to know because my car now has the security light and i have already tried the spare and no change.
Old May 19, 2011 | 02:54 PM
draggz28's Avatar
the problem is still there damn tryed the spare key lightly used a wire brush on both keys now they are just shiney lol and i also blew some computer dust remover spray in the key hole and still the same light even diconnected the battery fo 15 min
Old May 20, 2011 | 03:25 AM
myk's Avatar
myk
I bet it's the lock cylinder. Happened to my '97Z as well...
Old May 27, 2011 | 10:59 AM
draggz28's Avatar
Bumppppp
draggz28's Avatar
bumpppp
draggz28's Avatar
bumppppp
Old May 27, 2011 | 11:00 AM
draggz28's Avatar
bumpp it
draggz28's Avatar
you gellie
draggz28's Avatar
bumpppppin
draggz28's Avatar
bummmp
Old May 27, 2011 | 11:01 AM
draggz28's Avatar
pumpppppp
draggz28's Avatar
bumpinnnn
Old May 27, 2011 | 11:02 AM
draggz28's Avatar
bumppppp
inin
