Sponsored by: CARiD
oil filter upgrade
Old Mar 26, 2011 | 09:10 AM
farmington's Avatar
Default oil filter upgrade
Is there a longer filter upgrade for LS1 motors? Went and bought my first oil filter today and think there has to be something bigger?
Old Mar 26, 2011 | 09:44 AM
Jays_SSZ28's Avatar
The AC Delco PF61.
Old Mar 26, 2011 | 09:52 AM
1FASTZ28's Avatar
That's the one I use also.
Old Mar 26, 2011 | 10:37 AM
killagt's Avatar
mobil 1 M1-302 or wix 1060
Old Mar 26, 2011 | 04:25 PM
sjsingle1's Avatar
or a royal purple 20-59
Old Mar 26, 2011 | 07:15 PM
zfastss's Avatar
Wix 51522
Old Mar 26, 2011 | 10:13 PM
guy7bmwm83's Avatar
What exactly is the benefit of having a larger oil filter? More storage for contaminants?
Old Mar 27, 2011 | 12:58 AM
killagt's Avatar
more oil and catch more shiit, but to me, factory size is good enought. cause my car take 5 quart oil with factory filter, and with large filter it take 5.5 quart, I hate buying extra quart and pay 4 dollar a single quart, and 5 quart is just 13 dollar ^^. I use to use large filter M1 302 or Wix 1060, but end up just go back to factory filter size cause i hate buy extra quart every oil change ^^.
Old Mar 27, 2011 | 05:30 AM
farmington's Avatar
thanks, this was exactly what I was looking for.
Old Mar 27, 2011 | 06:43 AM
GTMLS3's Avatar
The larger filter has more filter media area. The flowrate from the oil pump is the same in both cases, large filter or small filter. The filter efficiency is affected by the flowrate thru the filter media. So, with less area flowrate, for the larger filter, the efficiency of filtration will be better.
Old Mar 27, 2011 | 06:51 AM
ULTIMATEORANGESS's Avatar
is clearance ok with these longer filters?
Old Mar 27, 2011 | 10:21 AM
Anthony Williams's Avatar
I use to run the long one from the 6L truck app but kept seeing dings in them oil changes, just switched to the LS9 AC = uses a stronger housing.
Old Mar 27, 2011 | 08:03 PM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Always ran Wix 51522 on ALL my FBodies. Never had an issue. Here's something I posted a while back on the subject.
51522 (Larger filter) - specs say that it filters 15 microns
51042 (Smaller filter) - specs say that it filters 19 microns
Here are the specs:
Part Number: 51522
UPC Number: 765809515222
Principal Application: AMC (82-86), GM, Saturn (93-08), Jeep (81-86), Isuzu (03-08), Saab (06-08)
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.526
Outer Diameter Top: 2.921
Outer Diameter Bottom: Closed
Thread Size: 13/16-16
By-Pass Valve Setting-PSI: None
Anti-Drain Back Valve: Yes
Burst Pressure-PSI: 290
Max Flow Rate: 9-11 GPM
Nominal Micron Rating: 15
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.734 2.430 0.226
Part Number: 51042
UPC Number: 765809510425
Principal Application: Various GM Cars & Trucks (75-76) (96-08)
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.404
Burst Pressure-PSI: 320
Nominal Micron Rating: 19
Gasket Diameters
Just thought some might want to know this. The 51522 IS A BETTER FILTER that does NOT impede flow!
Old Mar 28, 2011 | 01:19 PM
Chrismikeb's Avatar
It really bothers me that the filter for my 240sx is bigger than the one for my camaro with a motor more than twice as big...good info
Old Mar 28, 2011 | 10:39 PM
ccrook19's Avatar
WIX and Purolator filters are pretty good known filters, almost anything than a "FRAM"
Old Mar 29, 2011 | 02:18 PM
DWake's Avatar
I use the kn filter for mine every oil change.
Old Oct 2, 2019 | 10:40 PM
Goes2fast's Avatar
I have been using Royal Purple filters since they came out and have noticed my oil stays clean longer. Before I was using Wix and I tried K&N and Hastings as well.
