Sponsored by: CARiD
Chirping??
Old Apr 12, 2011 | 01:02 AM
MEGATRONSS's Avatar
Default Chirping??
I've done a few searches but haven't come up with much for this.
I have the bad chirping under the hood on cold startups. BAD. After the car warms up for 10 min or so it goes away completely. It also speeds up with Rpms.
I've replaced all the pulleys, tensioner ac etc.
Each time the noise goes away for about a week maybe a little more then comes right back.
I did install underdive pulleys before the sound started. The belts are aligned right I believe.
Any fixes???? I'm getting really frustrated and all the pulleys have been changed with no luck...and when they are changed it stops but comes right back...
Old Apr 12, 2011 | 04:38 PM
libertyforall1776's Avatar
Check to make sure you aren't leaking any coolant across the engine, or other fluids, that could contribute to the return of the sound... I have the same annoying issue, still haven't completely nipped it in the bud.
Old Apr 12, 2011 | 05:33 PM
colinpd137's Avatar
I have the same issue, been told its the belt tensioner but i haven't gotten around to replacing it yet. AC tensioner on the bottom is where my loud chirping is coming from
Old Apr 12, 2011 | 05:46 PM
^ Replaced my AC tensioner as I was told that was the chirping cause, but it came back... Grr...
Old Apr 12, 2011 | 05:50 PM
colinpd137's Avatar
How old are your belts? When i got my serp and AC belts replaced it reduced the chirping by 3/4th of the noise, just need to get my tensioner on now.
Old Apr 12, 2011 | 06:19 PM
LOL, before that was done, late last year, I did replace both belts. Maybe it's the OTHER tensioner in my case, or some pulley. Annoying process of elimination.
Old Apr 12, 2011 | 06:26 PM
MEGATRONSS's Avatar
Yeah my belts are brand new, just even went to a slighty smaller belt.
Could it be that the crank pulley is throwing the belt out of alignment?
Old Apr 12, 2011 | 10:46 PM
BoricuaHec01's Avatar
Formally Simplɘ Jack
I wonder if this is the chirp that I have. I have the same thing like megatron, when I start my car on cold start there's a weird clicking noise or I guess chirp that eventually goes away when I drive for a bit. A week after I got my car I did a radiator flush, hopefully they didn't mess anything up, and I don't remember if I started hearing this before or after I got a radiator flush :/ Oh and when I did the radiator flush, for three days straight my car was leaking antifreeze when I would first start the car, they tighten the holes where it was coming from so it stopped, that was prolly the issue or I heard it was normal to leak antifreeze the first few days of getting it changed. But any who, I just got used to this sound, could after all be normal, not really 100 percent sure if your chirp is my chirp.
Old Apr 12, 2011 | 10:49 PM
colinpd137's Avatar
Yup! Thankfully its not an "expensive" imo ;P
Old Apr 12, 2011 | 10:57 PM
poltergeist 02's Avatar
just fixed my chirp on accident. i needed to replace the alternator and when i did magically the chirp was gone. would have never thought that the alt would make those noises. i thought it was a peske belt that wouldn't quiet down. so before you go replacing pulleys on a whim check your alternator out and see if that might be it.
Old Apr 12, 2011 | 10:58 PM
colinpd137's Avatar
Hmm, noted check it out. i may have spoke to soon lol
Old Apr 12, 2011 | 11:00 PM
I believe the noise of my chirp is coming from the inside of the intake manifold, but could be wrong. Please don't tell me bad news guys lol.
Old Apr 13, 2011 | 01:00 AM
99huggerorangeZ's Avatar
turn on you a/c when the chirp happens, if it goes away it is your a/c compressor clutch that is faulty.
Old Apr 13, 2011 | 08:16 AM
I gotta try that. If that's the fault, u think it's because of the radiator flush? I'm just worrying myself for nothing, think every is fine on my end lol.
Old Apr 13, 2011 | 08:51 AM
cemlsx's Avatar
I've got weird chirping on my v6 when its cold too .. it seems to go away once the engine is warmed .. Im pretty sure its the belt / tensioner or something that has to do with that assembly ..
Old Apr 13, 2011 | 09:04 AM
But would this have anything to do with a shop doing a radiator flush?
Old Apr 13, 2011 | 11:37 AM
Post
My chirping started actually after a GM shop replaced my alternator under warranty.
Old Apr 18, 2011 | 06:18 PM
Allright so I officially have the same chirpity chirp chirp. Does this have anything to do with a radiator flush did I did a couple months back? I'm not sure if this started happening before or after the flush bcuz when I did a flush I was paying more attention to any noise and it so happened that I noticed this chirp. Is this a bad thing? What's the official verdict of this?
Old Apr 19, 2011 | 09:37 PM
MEGATRONSS's Avatar
I doubt it has to do with a radiator flush I it was a few months ago, any fluid on the belt prob if off by now.
But mine never did it before I put the underdrive pulleys on, can my new crank pulley or alt pulley be throwing the pulley off track?
And tried to AC turn off before and it doesn't matter. After replacing my tensioner and ac pulley it stopped both times, but came back after a week.
Again this never happened before the aftermarket pulleys went on..
Old Apr 19, 2011 | 10:40 PM
LeftySS's Avatar
I took my car into GM under warranty 2 times for this. Both times they replaced the belt and the chirp came back. I then proceeded to buy a goodyear gator back serpentine and ac belt and have never had the chirp again. Not saying this is the answer but is something to try.
