Security Light / Car Not Starting
It requires some wiring ability though. For the LT1 cars: battery & ignition power, ground, VATS wire, and alarm (if using with a remote start). See my attached diagram I modded for the Corvette. Later cars used one or two more wires. It will permanently fix VATS problems like the ones in this thread. A Google search will likely turn up someone that has used it on your vehicle.
One other tip: Solder those connections. Foldover taps/Scotchlocks lead to intermittent connections.
From the above site:
