synthetic oil in high mile car
I bought my 01 SS with 136k on the clock. First 2 oil changes I used Mobile1. I've since changed to Castrol Edge and my valvetrain noise disappeared.
Next oil change for the Escalade (LQ9) I ditched the Mobile1 and used the Edge. Guess what? Even my wife could notice how quiet the motor itself was running.
I'm sold on Castrol Edge. I as well have noticed my oil getting cleaner and cleaner when I change it.
Ain't nothing wrong with Pennzoil. Pennzoil Platinum and Ultra are very popular synthetic oils around here and other car circles as well. You can't HURT anything by switching to synthetic, so I say why not unless cost is an issue. If a leak pops up then fix it. The idea of keeping dino oil around just to deny a potential problem isn't wise...
Too many detergents? That's an interesting thought.
Pennzoil Platinum is one of the better widely available oils on the market, and so is Ultra which is the same base-stock (Shell XHVI) with an improved additive package.
As far as valvetrain noise, obviously additive packs are different between manufacturers and even between product lines of the same manufactures. Also keep in mind that one brand 5W30 will not have the same viscosity "curve" as another brand's due to differing base-stocks, and type and amount of VII's. You can look for the real data on the product data sheets. The HTHS is arguably the most important since it is probably most analogous to the operation of the oil at operational temperature in an engine. If you are somewhere in the 3-3.5 range you are probably fine in an LS1. Castrol's data is a little skimpy on their data sheets though (they list the "minimum specs" typically and not the actual specs). German Castrol 0W30'd spec for HTHS is a 3.5 FWIW.
If you want to learn a lot about oil, I would suggest avoiding taking too much advice on car forums and go somewhere like bobistheoilguy. If you believe in used oil analysis there are usually a lot of them posted for various cars, engines, and oils.
One last bit... All oil will thin if you heat it up, like in racing for example. If you are overheating your oil then the correct thing to do is get an oil cooler. Excessive viscosity is a bandaid and will cause excessive wear at low and regular temperatures.
