- Camaro and Firebird Warning Lights<br>Important information to help you understand your Camaro or Firebird.
Low Coolant Light Keeps coming on.
You may need to top if off and check level again to see if its low due to a leak.
PS: is there really a low coolant light on all fbodies or is it just a pontiac thing?
I'm chasing leaking coolant issues myself n would like to know where to look for this light in cluster?
Thank you, this was the type of answer I was looking for. I wanted to make sure there was a sensor before I started unplugging stuff. Now that I know where it is located, I can check and clean hopefully it just needs to be cleaned.
I had a feeling you didn't fix it, but wanted to wait it out. The sensor is a funny little guy and will work fine untill it gets pretty hot.
And no the later f-bodies do not have the sensor. Only the 98 and 99s had it. Maybe the 2000's, but I'm not sure on that year.
Some people will tell you that you don't need the sensor - which I don't believe to be true. Its there to keep you from introducing air in the system if the level gets too low. It saved me from catastrophe when I had a bad water pump injecting air in to the system. Very glad I replaced it. $20 well spent!
I siphoned coolant from the tank in to two milk jugs. You just need to get the fluid to the level where you can see the sensor inside the radiator. You will see how the clip works on your new part. Just undo the clip, take off the electrical connector, and then the old sensor twists/pulls out. Afterwards, just pour the coolant back in the radiator and tank. If any air is left in there it will self bleed out of the system.
Purists will tell you that you should throw away the old coolant and never re-use it. IMO - its not that big of a deal. I'd rather siphon it out vs. go through the hassle of putting the car up on blocks to drain the radiator. (I live in a place where that's challenging.)
