AC - O-ring question 99 - F-body
Old 07-28-2011, 09:01 AM
robertbartsch's Avatar
Default AC - O-ring question 99 - F-body
Are there any conventional 0-rings in this system?
After pulling it a part, I'm just seeing fittings that have permanent black seals and no conventional o-rings.
The kit I bought (compressor, drier, oil, o-rings, orifice tube) seems to come with conventional o-rings that are common on older 12a systems.
Thanks.
I'm assuming the black rubber fittings are re-usable; is this correct?
Yes - I will vacumn before a recharge..
Old 07-31-2011, 10:43 AM
FiredUpZ28's Avatar
No they are specific to the car. Whenever the A/C system is opened up the accumulator and its adjoining seals should be replaced, as well as the seals on the components you removed. Sometimes you get lucky and they don't leak when reused, but per GM Service Info, they should be replaced. I'd say use the seals the kit came with if the compressor and FOT aren't OEM.
Old 07-31-2011, 05:50 PM
t/a98's Avatar
They are like 2 bucks a piece at auto parts stores, replace them. It's alot cheaper than the freon you'll be buying to refill it next time. Don't forget to put pag oil on them.
Quick Reply: AC - O-ring question 99 - F-body
