How does oil get on the knock sensors?
I am replacing the knock sensors on my 98 Camaro SS. They had oil all over them and in the bottom of the valley cover openings where they sit. There was no oil on top of the valley cover. Are there O-rings or gaskets below the valley cover that I need to replace? or is the oil in there normal? Thanks
Ryan
Ryan
Yes, there are 2 rubber seals that goes in the valley tray, the knock sensors slide in the seal to prevent leaks. Seals have probably cracked over time.. The seals are not hard to replace, and not really expensive either, but You will need to go to the dealership to get them. local parts guys not too helpful with these. I got mine from my local dealer, they had them in stock.
All this probably applys to my 97 too right ? I noticed oil on my sensor when I replaced it. How pressing of an issue is this since it's probably been doing this for awhile ? Just curious
