Fan location
One fan has 9 blades and one has 6 or 7. One motor is taller than the other.. I'm guessing the taller one is stage 2? I just set the blades and motors in the shroud in the picture but I need to know where they are suppose to go.
The fans ALWAYS come on together ...either on LOW speed or HIGH speed. Or off.
They don't come on separately. Not for an LS1.
It doesn't matter though.....they work together....on or off, low or high.
Maybe check with the dealership, just make a phone call, to see if those fans work TOGETHER like the 98-02 fans do.
But either way....you're cooling is going to be fine as long as they are working properly with the temps and PCM.
Me...I would drive over to the dealership, walk out into the shop and ask the A/C technician. He'll know.
