Sponsored by: CARiD
cruise control still doesnt work
Old Aug 29, 2011 | 09:03 AM
LeanPocket's Avatar
Default cruise control still doesnt work
-3rd brake light works
-brake light switch replaced
-cruise control release switch replaced
-cruise control fuse replaced
AHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH
i dont know what else to do
Old Aug 29, 2011 | 11:26 AM
LeanPocket's Avatar
any ideas?
Old Aug 29, 2011 | 03:04 PM
LeanPocket's Avatar
i give up..
Old Aug 29, 2011 | 03:05 PM
LeanPocket's Avatar
You win cruise control you win
Old Aug 29, 2011 | 04:09 PM
2001NBMZ28's Avatar
Not my forte, never even tried my cruise control since buying the car new in '01 LOL. Which fuse was blown? Is the AC working? My A/C CRUISE fuse feeds the AC compressor relay, cruise control switches and module. TTT for ya.
Old Aug 29, 2011 | 06:56 PM
LeanPocket's Avatar
ty for the reply
my cruise control fuse was replaced for troubleshooting purposes, it looked worn but it wasnt blown in the middle
Old Aug 29, 2011 | 08:24 PM
wssix99's Avatar
Save the manuals!
Maybe the switch on the turn signal stalk?
There is a plastic cover on the side of the turn signal column that should come out and expose the connector. I'd think you should be able to test the switch at that connector.
Old Aug 30, 2011 | 10:53 AM
LeanPocket's Avatar
thats my next culprit.. i sure hope thats it..
Old Aug 30, 2011 | 01:30 PM
Schnell's Avatar
Isn't there a switch that goes off the clutch pedal as well? If I recall either this switch mount or the brake switch mount always seems to break. One of those I put back on a few years back with zip ties. I'll have to look if I have or posted pics.
Old Aug 30, 2011 | 01:42 PM
Schnell's Avatar
I can't find pics on it. The normal failure for CC is this clutch pedal switch. The switch is above your shin not down on the floor at the master cylinder. Make sure the switch mount it not broken and/or the switch is adjusted properly.
Old Aug 30, 2011 | 10:31 PM
LilJayV10's Avatar
Have you checked to see if you are getting power to the CC unit itself? I would have to look at a wiring diagram to see if it has constant power or just when the CC is engaged.
Old Aug 31, 2011 | 09:18 AM
LeanPocket's Avatar
I have a a4 so I dont have a clutch peddle switch
Old Aug 31, 2011 | 09:19 AM
LeanPocket's Avatar
I'll try to check that.. might have to take it in to diagnose this
