New P/P TB, P0507, Idle problems, ugh!
So I just got a LS1 TB Ported/Polished/100% Throttle/Epoxy Mod/Coolant Bypass...for some reason day 2 after install im throwing that P0507 code, my car is idling at 1,000rpm, and when im driving and throw it in neutral it hangs at 1500-2000 rpm until the car comes to a complete stop, then it just drops quickly back down to 900rpm...ive tryed searching the forums, and I did the manual reset for the TB, the car ran fine with the original TB, and theres no enlarged hole on the TB Plate. Any new info out there, or just any help would be great. I dont wanna replace IAC that worked great with previous TB
I had the exact same problem minus the code with mine, you need to take the TB back off and adjust the idle screw for the blade so it will close more. I did that and my hanging idle issuse disappeared.
To the OP here is my old thread where I had the problem. https://ls1tech.com/forums/general-m...v-bigtime.html
Well bank 2 is the passenger side oxygen sensor and I think if its sensor 1 is upstream and sensor 2 is downstream. Again my car was screwing up last year and I ended having a bad 02 sensor and replacing it helped a lot. All of a sudden about June (this year) mine started doing it again and all of a sudden last week my car started running like $hit and !!bam! bad 02 sensor bank 1 sensor 1. Whats funny is my warranty on the denso I bought last year just ran out. I am just gonna give the bosch 13111's a shot when I do LT's.
Well having an o2 go bad the exact same time you switch TB's is just highly unlikely, but possible. If closing your blade more doesn't work take the TB off again, take a light and shine it behind the blade and see if there is an even gap all the way around the blade (there should be some light showing around the edge but not ALOT) it's possible whoever did the work on your TB removed too much material and its allowing too much unaccounted for air around the blade.
I replied in your duplicate thread. Have you gotten this sorted out?
https://ls1tech.com/forums/generatio...-problems.html
