Sponsored by: CARiD
Clunking In rear passenger side PLEASE HELP!!
Old Oct 3, 2011 | 11:30 AM
GUTZ28's Avatar
Default Clunking In rear passenger side PLEASE HELP!!
Hey guys I have a 99 Z/28 and I just started getting some clunking sound from my passenger rear end at least that's where it feels like is coming from. It only happens from a dead stop when I accelerate I feels like a couple of clunks. Please help. I do have access to a lift down at Mcdill AFB so any help in determining whats wrong would be appreciated. Thanks.
Old Oct 3, 2011 | 11:47 AM
GUTZ28's Avatar
OH and its has an A4 tranny and its has 81,000 miles.
Old Oct 3, 2011 | 01:08 PM
shepss217's Avatar
mine just started making a similar noise only when i'm going slow and making a sharp turn, it's pretty loud, i'm thinking my limited slip diff is going bad, i thought it was something up front until it started doing it even after the wheel was straightened out and now i can hear it more clearly in the back
Old Oct 4, 2011 | 07:15 AM
ccrook19's Avatar
a bad u joint is a possibility.....
Old Oct 4, 2011 | 01:19 PM
GUTZ28's Avatar
Im gonna put it on the lift tomorrow and see whats going on maybe I'll be ordering some goodies from UMI.
Old Oct 5, 2011 | 04:41 PM
Zlow28's Avatar
check your transmission mount
Old Oct 5, 2011 | 07:05 PM
ls1okie's Avatar
Lower control arm bushings.
Old Oct 5, 2011 | 07:07 PM
VinR1's Avatar
Make sure the spare and jack are secured...serious
Old Oct 5, 2011 | 07:11 PM
GUTZ28's Avatar
Check out my latest post .
https://ls1tech.com/forums/suspensio...-bar-fail.html
Old Oct 5, 2011 | 07:20 PM
Z28Z06's Avatar
With 110 thous on my 2000 Z28 A4 the trans mount failed, and made loud clunks under acceleration. The right rear axle failed at the bearing and also had to be replaced, it made a louder and louder whine. The axle had impressions on it from the bearing and may have been oil starved.
Old Oct 5, 2011 | 09:46 PM
Metal Muscle's Avatar
This. The passenger side rear is the location for all that, make sure that they're tight
DarkhorSe_SS's Avatar
I have the same noise coming from my driver side rear but mainly when it hits dips or small cracks in the roads.. seems to me like something is loose in the rear or maybe cracked.
Saw ur phb thread op that is crazy man...
Old Feb 1, 2014 | 07:07 PM
Pilgrim's Avatar
I had this same problem. After chasing for days and pulling on everything under the car, I found the rear trailing arms were the problem. Replaced with founders 3 piece poly joint lca's and said goodbye to the clunking.
Old Feb 1, 2014 | 11:34 PM
93Euphoria's Avatar
love how nobody in these types of threads mentions torque arm bushing..
