Swapped out computer,car blows white and black smoke now!?
I ordered a ECU off ebay that was matched to my VIN for a 2000 trans am and then took it to a tuner who supposedly put a tune for my cam and 42 pound injectors directly on the computer while it was still out of the car. I then had the computer ECU installed on my car and hell broke loose. The car started but blows black smoke when you give it gas and blows white smoke when idiling and constantly tries to stall out and die. Tried putting original computer back in but now the car runs very rough and only starts when you give it gas and still blows white smoke when trying to die. PLEASE HELP I have no idea why its doing this
Did you check the 4 or 5 ground wires that attach to the back of both heads. 2-3 on the drivers side head and 1 or 2 on the passengers side head. ((depends on year)) Reach back behind them and feel the bolts, make sure they are all tight. When mine came loose my engine barely ran, passengers side wouldn't fire and raw fuel was shooting out the exhaust pipes.
My mechanic says he checked those grounds first before anything else but I think I'm gonna just grab a flashlight and feel around in there with my own hands to make sure at this point. getting pretty desperate to get this thing running properly
There's 3 ground connections in the wire bundle within 10 inches of the PCM......
Also....start the engine and grab those wire bundles and move them back and forth, side to side......see if the engine runs better at times. Thats a tell tale sign its something in the wiring harness.
I think it is a loose ground or some kind of wire because the problem comes and goes randomly. My friend told me his school has a diagnostic program that locates loose disconnected grounds and says where they are. Seems like dealerships would have this diagnostic system also. Should I try and take the car and have this done?
