high pitched buzz coming from inside
The sound sounds like its coming from behind the stereo. its an electrical whine. i had heard it once before, replaced my bad water pump, now im hearing it again. im assuming people have experienced this, i ahve heard it in other cars, but if yall would like a video i can post 2. the electrical whine corresponds wit hthe throttle
its annoying![Bulls#!t](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_bs.gif)
heresa vid. had to step down quality to email it
http://youtu.be/CaHYi_RxjuA
its annoying
How much aftermarket stuff do you have hooked up to your car. In my old car, i have a amp and some huge subs, so when i had everything turned up to the max drawing the most power from the battery, you could hear it whine when giving it gas, almost like hearing the car charge the battery at the same time.
NOTHIN stock stereo and electronics. i heards it when i first got it, then it went away, after picking it up from the shop i hear it again.
i dont feel like taking it back over there anytime soon. first snow is tonight
![Bomb](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_bomb.gif)
May also want to check the ground on the stereo head unit and ensure it's properly attached or run an independent. But also check for power steering whine but to me it sounds like its coming through te stereo. If you turn up your radio does it get louder or change? Or if the stereo is turned off?
called the shop, taking it to them monday, im assuming a ground was just nudged off its spot
