SEAFOAMED 3.4l Camaro and now 13mpg in town
i sea-foamed my Camaro via brake booster hose and gas tank, it returned 16-17 mpg city for 2 months and now the car has been giving me 13-14mpg in return *TOWN* , i decided to put some sea foam through the crank case and later into the gas tank. still mpg did not change. what went wrong? i did not change the plugs or the fuel filter... don't know if i should.
also car has a strong fuel odor when starting it up....
any help will be appreciated
when im driving in town, itll throw a code, check engine light for a minute or two and it clears out! i scan it and nothing shows. it has started to hesitate when i step on the gas.
I'd pull the plugs first and check them. If a car hasn't been seafoamed before and has a lot of miles it can usually foul the plugs, if its not the plugs then i would check the O2s next
