m6 clutch pedal squeak
My car is in storage and I noticed when I got in it this morning to do my weekly interior fresh up that pushing my clutch pedal down it makes a squeak. I tried spraying wd40 all over parts of the pedal that moves and it still didnt fix it. I dont know if I missed the top part (hidden under the panel of the dash) or not because there's no way I can fit my head under there to see where exactly it is. Does anyone have a simple solution? Or should I just take the panel off and get a better view?
Save the manuals!
Yep, that's what you need to do. Remove the lower IP panel under the dash and then get your noggin up under there. (I recline my drivers seat and lay in it upside down with my feet at the headrest.) The squeaking parts and pivots are up behind the cluster gauges. The squeak commonly comes from the clutch pedal return spring. A good one should have two "legs" that hook in to two plastic bushings in the pedal housing. Commonly one of the legs breaks, twisting the spring and causing it to squeak. If your spring is still good, some white lithium grease on those spring legs should do the trick. (White lithium grease is a proper lube for metal on plastic. Other petroleum based lubes, like WD40, contain solvents and can dissolve the plastic.)
