Sponsored by: CARiD
SES Light is on... FML.
Old Dec 17, 2011 | 09:34 PM
703 CAMAROSS's Avatar
Default SES Light is on... FML.
Well I drove to work this morning started up fine drove like normal although it does have a slight knock (was told it was a rod knock from a more experienced tech then me). I think today it decided it was finally going to get worse. So I start my car up. Let it sit till the piston slap goes away. Then 10 min later I start driving. The same knock I heard before got even loudour and then BAMMMMM! ses light comes on... I don't have a tech 2 where I work. Does anyone know a place that can scan for codes like maybe car quest or napa?
Old Dec 17, 2011 | 09:38 PM
Camarosteve44's Avatar
Not sure where you live but i know autozone around here does it
Old Dec 17, 2011 | 09:50 PM
I live in northern va. I would not trust anyone at my autozone/advanced auto even touch my car! They are so dumb its not even funny
Old Dec 17, 2011 | 09:54 PM
02ws.sik's Avatar
Go to autozone tell them to check the light they come out and plug it in. They will show you what it is. If its nothing thats wrong they can not clear it but you can press it to clear the ses. Sounds like a motor going bad any vids?
Old Dec 17, 2011 | 10:27 PM
No I'm on mobile so I can't upload a vid I guess Il go to advanced and have them scan it. I have a new engine waiting to go in anyways if mine is bad... My engine is going bad though... Rod knock, I have blow by, rear main seal leak, and oil pan leak. I go through half a court of oil a week...
Old Dec 18, 2011 | 02:02 PM
Ok guys it says everything is ok accept htd catalyst and A/C Refrig they both say n/a... What does this mean
Old Dec 18, 2011 | 02:05 PM
P0137 it says
Old Dec 18, 2011 | 02:09 PM
Arctic_Z's Avatar
Originally Posted by 703 CAMAROSS
P0137 it says
that code is for rear 02 sensor. I ignore mine
Old Dec 18, 2011 | 02:23 PM
Lol yeah it said bank 1 sensor 2 low voltage and also another code that was the same 1 but it said pending...
Old Dec 18, 2011 | 02:38 PM
02ws.sik's Avatar
Just delete it.
Old Dec 18, 2011 | 03:07 PM
Bank 1 sensor 2 low voltage do you think its a sensor or cat? I don't get it... It dosent explain why my knock sounded allot louder
Old Dec 18, 2011 | 07:13 PM
yourownself's Avatar
Get yourself a multimeter and test the yellow wire coming out of the ign switch. If there's no voltage there, you have a bad switch. You can test for voltage at the signal wire on the starter solenoid as well.
Old Dec 18, 2011 | 07:14 PM
Sorry, posted this on the wrong thread.
Old Dec 18, 2011 | 08:00 PM
^^^ Lol I was like what?
Old Dec 20, 2011 | 01:17 AM
chrysler kid's Avatar
Ok check your oil. Make sure to look for tiny metal shavings in the motor.
Loud knocking can be a rod or it can be a broken valve spring.
Old Dec 20, 2011 | 07:29 AM
Thanks Il do that.
Old Dec 20, 2011 | 12:12 PM
94'BLKBRD's Avatar
basketball or tennis court?
Regardless, that's a lot of oil.
