Dash removal
The previous owner of my camaro had a xm radio glued on the dash. Well when he sold the car he just pulled it up off of it and it took a 2 x 2 inch piece of the vinyl off and now I've got a big brown gawky spot where you can see the foam underneath. ( to explain what part I'm talking about) Its the area right above the radio where its flat. How hard would it be to replace the front part of the dash.
This link will show you how the dash is removed,
https://ls1tech.com/forums/drag-raci...-pictures.html
It's not difficult, just need to have patience. I pulled one out in an hour a couple weeks ago but I am really familiar with fbodies.
Pics are being uploaded now but in that link that dash had a gauge pod on it that would cover up my bad spot. Where can I get that dual gauge pod? and would I have to pull the dash anyway in order to run the wires if so i might as well replace it but if i can just remove the back section and run them It'd be alot easier.
hey guys...newby to lstech.....a ? about pulling the dash. will/does the dash in these (99 Fbody) rotate forward like most GM's on a set of pegs down by the kick panels?
I'm about to do a dash removal in 1 and I haven't even sat in 1 of these cars.....my "latemodel" is a 1981 TA. Any helpfull hints would be much appreciated.
I've gotta remove EVERYTHING under the windshield!
