Ignition cylinder or ignition switch?
The security light is not staying on OR flashing. It comes on with other dash lights when key is first turned, but goes off shortly after.
The car has attempted to start twice in about 200 attempts. After one time, it ran fine. The second time, the engine immediately lost momentum and shut off as if it lost spark.
I've tapped the starter with a hammer while someone was trying to start it, with no luck. I do not have a voltmeter to check power at any point. I've switched fan relays with the ignition and starter relays. I've checked all fuses. I've cleaned surfaces of the keys, including the chips on both sets of keys. Nada.
So...which is it...the switch or the cylinder? Part of me thinks its a bad connection in the cylinder, since it has attempted to start twice. If the switch were bad, I figured it would NEVER attempt to start again. However, if its just a bad connection in the wiring within the cylinder that reads the chips on the keys, why is my security light not lit or flashing?
HOWEVER,, You are a six speed car, You really need to have a look at your clutch switch, and make sure it is working, If it is not, you will not get the signal to the starter relay, as it goes thru the clutch switch. Hope this helps.
I've almost completed an install of a new ignition switch. I'm not sure HOW some people are able to do this without removing the steering column per shbox's instructional page. It's been pretty smooth so far... hopefully this solves the problem!
Also, just put the starter back in, and was reconnecting the battery. The engine cranks for about a half second and then the ground lead came loose because I jumped (not expecting that!!)... Reconnected battery and never had it do it again. Still same symptoms...
So, ruled out the starter, and ruled out the ignition switch. Lock cylinder is looking more and more like the problem...anybody agree? When I get some folks over here I'll have them try to start it while I test the power at the relay. If the lock cylinder were bad though, would the relay even GET power?? I feel like I hear it clicking when I try to start the car.
Purchased a new starter, and problem was solved. Just don't know why the first auto store said the starter was good...I even saw it run on their machine, so there were no indications the starter was bad. Just a strange situation! Thanks for all the guidance everyone!
