Could this cause my squeaking??? (pic)
Old 12-27-2011, 12:01 PM
777Shock777's Avatar
Default Could this cause my squeaking??? (pic)
Hi all,
I started having a squeak in my engine bay about 2 months ago.
I figured it would be the cold weather, (it went away after warming up), but as of recent.. it just keeps squeaking!
I looked at the belts and they look fine, I'm thinking of cutting the A/C belt to rule that out.
But I think it could possibly be the tensioner thats at the top left of the engine bay- the one closest to the battery.
I was checking to see if I could tighten the pulley that is on it - and the whole tensioner actually moved a bit 0_o
I added a pic, does that look like its loose?
The squeaking increases as I accelerate.
LS1tech people are my heroes
Old 12-27-2011, 12:33 PM
transambrotha's Avatar
that's your main belt tensioner, it could be going bad and squeaking or it could be one of your A/C idler pulleys or your A/C tensioner itself. Your best bet is to spray each pulley while its running with a little bit of WD-40 or some other lubricant and listen for it to go away. Then you know where you gotta go from there. My instinct says it's one of your idler pulleys since my car was doing the same thing. I just removed them and regreased the bearings and they shut up. lol
Old 12-27-2011, 06:10 PM
sjsingle1's Avatar
it is the pulleys...or belt........hope that gives you a clue
Old 12-27-2011, 08:57 PM
94'BLKBRD's Avatar
My guess is the idler pulleys on the bottom next to the AC compressor. You can re-grease those instead of buying new ones.
Old 12-27-2011, 10:03 PM
jesse anaya's Avatar
wd40 or u coud get a pvc pipe put it to your ear then each pully 2 try and hear which pully is bad try wd40 first should b one of the pully berings is belt to tight
Old 12-28-2011, 02:09 AM
94'BLKBRD's Avatar
Belt can't be too tight since the stock tensioner/s are NOT adjustable.
Old 12-28-2011, 04:45 AM
Captain Double Post
BOBS99SS's Avatar
im going to say its the ac idler pulley same thing that happend to mine
Old 12-28-2011, 08:32 AM
Once I get off work today I'll cut the A/C belt, that way I can rule out anything having to do with the A/C side of things.
I planned on getting new belts on the 31st anyways.
Yeah I bought a can of WD40 and sprayed here and there and got it to shut up on the main belt, so I think its probably the main one.
Old 12-28-2011, 08:43 AM
Save the manuals!
wssix99's Avatar
Good heavens Batman! Whatever you do, DO NOT spray the pulleys (as suggested above) with WD-40. WD-40 is a low durability penetrating oil and the pulleys need grease. WD-40 should only be used to loosen rusty bolts on a car and nothing else. If you use it on a good pulley, it will dissolve the good grease that's there and will cause the good pulley to quickly burn out on you.
The best way to find a squeaking pulley is to use a mechanics stethoscope:
You can get them at many stores and they typically run $5-10.
Old 12-28-2011, 02:52 PM
thanks 4 the advice i used a pipe 2 hear it b4 works ok
Old 12-28-2011, 04:19 PM
...... WELL! now that I know that I will never do it again
I do need to get that mechanics stethoscope
I'll get one today! Thanks!
Old 12-30-2011, 01:01 PM
Hey wssix99, what do you recommend for a grease replacement?
(if your still following the thread)
Thanks
Old 12-30-2011, 05:09 PM
Save the manuals!
wssix99's Avatar
From the stickies: https://ls1tech.com/forums/general-m...r-pulleys.html
Quick Reply: Could this cause my squeaking??? (pic)
