Sponsored by: CARiD
do i need to replace the tranny and motor mounts at the same time
Old Dec 26, 2011 | 09:10 PM
Floorman279's Avatar
Default do i need to replace the tranny and motor mounts at the same time
my trans mount is bad, and was wondering if i get a poly trans mount, should i replace both motor mounts with polys at the same time? how hard is it to replace motor mounts?
Old Dec 27, 2011 | 12:40 AM
sjsingle1's Avatar
MMs are not the easiest thing in the world to change out.....best to do them if installing headers.......but i can GUARANTEE you that your MMs are SHOT......and your tranny mount is too........ its sometimes hard to see how bad it is till you take it out
Old Dec 27, 2011 | 12:43 AM
sjsingle1's Avatar
Old Dec 27, 2011 | 12:44 AM
sjsingle1's Avatar
Old Dec 27, 2011 | 10:34 AM
well my tranny one is causing the tranny to shake and do all sorts of stuff, and i saw somewhere that the polly tranny mount sits higher than the stock one, and raises the tranny
Old Dec 27, 2011 | 11:20 AM
LS1121's Avatar
Get a rubber transmission mount, and do the Poly Motor Mounts. This is what I did. If you think Poly Trans mount is the way to go please read the posts on here about them. Good Luck! Poly & Poly will have Vibrating on down the road.
Old Dec 27, 2011 | 12:11 PM
so your saying get a new gm mount?
Old Dec 27, 2011 | 05:18 PM
LS1121's Avatar
I have an A4 and I got mine at Autozone $17, if it breaks so what it's cheap and I know it.
Old Dec 27, 2011 | 06:09 PM
sjsingle1's Avatar
i have poly MM and tranny.............not a vib or a shake to be felt
Old Dec 27, 2011 | 09:32 PM
ok ill go with rubber tranny and poly motor
Old Dec 28, 2011 | 01:09 AM
ws6outlaw's Avatar
do you know what the part number is on that mount b/c i looked it up for my 98 trans am and i couldnt find one in stock anywhere. its like they don't even have one.
Old Jan 5, 2012 | 05:17 PM
98boxer's Avatar
Hopefully you are able to install new rubber trans mount yourself, because with rubber trans mount they are going to break again and again (depending on your driving). I bought two gm trans mounts and replaced 3 before i finally went with a poly trans mount.
If you do go with poly trans mounts, you will get vibrations for awhile over 50 or 60mph but after driving a few weeks vibrations get lesser and lesser till there almost non-existant. Imo, they are worth it.
