Sponsored by: CARiD
Cruise control module
Old Mar 15, 2004 | 08:03 PM
Mark IXZD 150's Avatar
Default I need an answer quick please... Cruise control module:
How does the module operate the throttle body? I want to put cruise on a car that is getting an LS1 put into it but need to know how it works. Thanks.
Old Mar 16, 2004 | 03:22 AM
DaddySS's Avatar
System Description
Cruise control is a speed control system that maintains a desired vehicle speed under normal driving conditions. However, steep grades up or down may cause variations in the selected speeds. The electronic cruise control system has the capability to CRUISE, COAST, RESUME SPEED, ACCELERATE, and TAP-UP or TAP-DOWN.
With cruise control you can maintain a speed of about 40 km/h (25 mph) or more without keeping your foot on the accelerator. When the driver applies the brakes, presses the clutch pedal or turns off the on/off switch, the cruise control turns off.
The main parts of the cruise control system are the following components:
The cruise control module assembly
The function control switches
The vehicle speed sensor (VSS)
The cruise control release (brake) switch assembly
The cruise control (clutch) switch assembly
The stoplamp switch assembly
The cruise control system uses a cruise control module assembly to obtain the desired vehicle cruise operation. Two important components in the module assembly help to do this. The first is an electronic controller, and the second is an electric stepper motor. The electric controller monitors vehicle speed and operates the electric stepper motor. The electric stepper motor moves a strap that is attached to the cruise control cable which moves the throttle linkage. The stepper motor operates in response to the electronic controller to maintain the desired cruise speed. The cruise control module assembly contains a low speed limit which will prevent system engagement below a speed of 40 km/h (25 mph) . The operation of the electronic controller is controlled by function control switches located on the multi-function lever. The cruise control module assembly has an electronic controller and an electric stepper motor to vary the throttle in each different cruise control mode. The module assembly is not serviceable.
The cruise control function switch includes the ON/OFF, SET/COAST and R/A (resume/accelerate) switches. The switch assembly provides driver control of the cruise control system.
The cruise control release (brake) switch, the cruise control (clutch) switch and the stoplamp switch assemblies are used to disengage the cruise control. The cruise control release (brake) switch assembly and the stoplamp switch assembly, mounted on the brake pedal bracket, disengage the system electrically when the driver presses the brake pedal. The cruise control (clutch) switch, mounted on the clutch pedal bracket, will also disengage the system when the driver presses the clutch pedal. When either pedal is pressed, the speed of the vehicle is stored in the cruise module memory.
The Vehicle Speed Sensor (VSS) is mounted to the automatic or manual transaxle assembly and produces an AC signal. The frequency of this signal is proportional to the speed at which the automatic or manual transaxle assembly output shaft rotates, which in turn is proportional to the speed of the vehicle. The AC signal is supplied to the Powertrain Control Module (PCM) where it is converted to the number of pulses per mile per second to determine vehicle speed. The signal is then sent to the cruise control module assembly and the speedometer assembly at a rate of 4000 pulses per mile .
Old Mar 16, 2004 | 03:50 AM
Plan B's Avatar
More in here.
http://auto.howstuffworks.com/cruise-control3.htm
Old Mar 16, 2004 | 09:34 AM
That explains quite a bit. Thanks. However, now I'm wondering if I can use it. That writeup says that the speed sensor (VSS) is mounted to the "transaxle", I assume that means the tranmission on a T56 right? If so, I may be in good shape. The only unanswered question is whether there are two cables to the TB, one to the accelerator and one to the cruise module. I looked on a friends SS which has cruise control but only see one cable on the TB which perplexes me.
Old Mar 16, 2004 | 09:53 AM
jimmyblue's Avatar
Moderator
Transaxle on 'vettes, inside the transmission on F-bodies.
On my F-body I have the traction control, so the gas pedal
and the cruise cables both go to that pulley cluster and
another cable fromthere to the TB.
Never looked at a non-TCS F-body so I don't know how
those have the cruise and throttle combining to pull the
throttle cam.
On the 'vettes with the electronic throttle, I have even
less of a clue.
Old Mar 16, 2004 | 01:37 PM
rushman's Avatar
I believe its the same on the non-tcs models, just one less cable going in.
