Sponsored by: CARiD
white smoke!!
Old Feb 13, 2012 | 10:45 AM
00_LS1_T/A's Avatar
Default white smoke!!
My t/a throws white smoke from the exhaust!! watt could it be!! it only does it sometimes!!
Old Feb 13, 2012 | 10:50 AM
omarrakeen's Avatar
more details? milage? is it on start ups or after it warms up? it could be just condensations...does it burn oil? you are not helping at all lol
Old Feb 13, 2012 | 10:54 AM
xBrandonx's Avatar
Is it cold outside?
Old Feb 13, 2012 | 11:21 AM
DOG-TWO's Avatar
Probably steam. Mine does the same.
Old Feb 13, 2012 | 11:26 AM
BOBS99SS's Avatar
Captain Double Post
yeah thats not enough detail to tell you anything,answer some of omarrakeens questions and we will be able to help you a lil more
Old Feb 13, 2012 | 11:44 AM
00_LS1_T/A's Avatar
Car has 130xxx miles... Does need an oil change... it does it when am driving around then am at a red light and it smokes for a bit but then it stops
Now its throwing Alot of white smoke of the exhaust! Oil seems fine! watt could it be! help!
Old Feb 14, 2012 | 02:32 PM
KevinR's Avatar
Check your coolant level. Could be a blown head gasket or worse, a cracked block.
Old Feb 14, 2012 | 02:46 PM
usafws6's Avatar
"What" could it be? Oil smoke is a blue ish and coolant smoke is white check the radiator for oil and the oil for coolant
Old Feb 14, 2012 | 03:56 PM
00_LS1_T/A's Avatar
Oil seems fine and no oil in radiator
Old Feb 14, 2012 | 04:27 PM
KevinR's Avatar
Is it constant smoke coming out, or only when you go WOT? Are you sure it's white? Can you post a video of it smoking?
Old Feb 15, 2012 | 09:58 AM
redtan's Avatar
If it's white smoke all the time, especially on a warm day with the engine fully warmed up, then it's most likely coolant being burned off from some sort of headgasket problem.
If it's only at WOT and only when cold outside with the engine cold, then it's normal and nothing to worry about.
Old Feb 15, 2012 | 10:05 AM
GMtechmatt's Avatar
white smoke headgaskets? do a leakdown and check but white smoke can mean headgaskets
Old Feb 15, 2012 | 02:14 PM
Jr.Samples's Avatar
^^^^^^^ What he said. Pressure test you radiator and see how well it hold pressure. Listen for leaks when you pump it up.
