Blinker not functioning, ideas?
I'm really not sure what it is. Maybe the bulb in the front is out? But I don't think so. I thought about fuses, but am not sure if that's the problem. The one thing I am thinking the problem is, is the switch. The actual lever that sticks out the side of the steering column. I have a feeling something in there may have gone bad. My reason being is this:
The windshield wiper intermittent speed is all jacked up. I will put it on speed 1, the lowest setting, and it will automatically jump to speed 5, keep wiping back and forth. I put it on speed 2, and it stays on speed 5. And sometimes when I turn it off, it will take 5 seconds or so to actually respond and turn off. And someone told me that the reason it's doing that is because of the switch, the actual lever, and it would have to be replaced.
Any ideas please? I need my lights fixed.
Will they blink with the flashers engaged?
Check out those rear bulbs and see if they're in good order. Your switch could be messed up considering your wiper issues, but check the bulbs first.
dum
You are probably low on fluid. Get some of this.
http://kalecoauto.com/index.php?main...&products_id=6
dum
it was under warranty. they were about to go home. i said fine hook me up with a loaner. they stayed late and fixed it.
A failing thermal flasher can also cause one side to light up and not the other. (There are posts here with people who had that issue and I've had it happen to me.) I'd try the flasher first. Its a lot less expensive and easier to install than a turn signal switch!
The one you purchased is an electronic flasher - but yes, odds are it will fix your problem. (If your hazards worked fine.) The electronic flashers are more expensive, but they are less picky than the thermal flashers and should last longer.
When you put it in - beware of a common pitfall and make sure you replace the correct flasher. There are two flashers under the dash. (Some people replace the hazard flasher and wonder why the problem still persists.) The hazard flasher is on the left rib under the dash and the turn signal is on the right rib.
... but that's not the issue here. The OP has a problem with the electrical system inside the car.
Having gone through this same saga before, a $2 light-bulb and a squirt of dielectric grease should be the first thing to troubleshoot here before dropping a coin on anything else.
I've had a blinker bulb blow years ago and I think IIRC, thats exactly what happened to mine. I changed it and they've been fine since.
I'm pretty sure thats what mine did.......
When I turn the hazard lights on, it flashes just fine. When I turn the blinker on, it lights up, the green arrow stays a steady green and the blinker is a steady yellow, no flash. So that must mean the bulb is fine, right?
