AC blower fan = more speed?
Wondering if there is a way to increase blower fan speed? My DD Chrysler 200 blow furiously and cools the car quick. Wondering if there is way to engineer a faster fan for 4gens?
Update June 14th
Unclogged my system by removing a bunch of stuck leaves...air pressure is restored to like new.
If your AC air isn't blowing hard on highest setting, remove the fan and stick a vacuum in towards the evaporator area and get as much leaves as you can, than take off your cowl grille and use compressed air to blow leaves out from the top. Your AC will feel like a new car.
Update June 14th
Assuming that its not clogged will the stock motor be able to handle more voltage without dieing? Now if the motor can handle the extra power will the fan be able to handle the rpm?
You could try running a power wire directly from the battery through a relay and switch....not sure if on full speed if it actually sees full voltage or not.
The fan and motor should be sble to handle higher voltage
Well after closer inpection of my system, found a bunch of leaves inside. Vacuumed them out from inside and blew a lot out from the cowl panel after removing my cowl grille. AC air blows now like it should...guess over time I didn't realize the system was getting clogged.
Air cools down the car quickly like a car of showroom floor.
