Sponsored by: CARiD
Small oil leak..
Old Feb 20, 2012 | 02:39 PM
01wss6's Avatar
Default Small oil leak..
I have a very small oil leak where the transmission and engine block meet. I jacked the car up today and looked in the inspection plate on the transmission and it is was dry with no oil. If my rear main seal was leaking would I have found oil inside the transmission when I looked in the inspection plate?
Old Feb 20, 2012 | 09:09 PM
01wss6's Avatar
anyone have any ideas?
Old Feb 20, 2012 | 09:17 PM
JaYZeig's Avatar
sounds like it may just be the oil pan, you are right though, if you had a rear main leak, youd see oil inside that cover on the motor.
there is also a smalllll chance that the rear plate gasket could be leaking..but chances are its more than likley the oil pan gasket.
Old Feb 20, 2012 | 09:24 PM
01wss6's Avatar
Thanks for your response!!! How hard is the pan gasket to change? Also could it be the OPSU slightly leaking because the gauge flickers ocassionally?
Old Feb 20, 2012 | 09:40 PM
JaYZeig's Avatar
no problem, pan gasket will be tough, you will either need to raise the motor, or lower the k member to get the pan completly out, because it weill not clearance the k member, nor the pickup with everything in tact.
id say your issue with the OPSU could just more than likley be the sending unit failing.
Old Feb 20, 2012 | 09:48 PM
01wss6's Avatar
I'm gonna have to look again when I have more time it almost lookes like some oil was coming down the passenger side of the block but didnt get a real good look at it. I really just wanted to make sure it wasnt my rear main seal because I just had my tranny dropped and really wouldnt want to drop it again if I dont have to. Thanks for the info!
Old Feb 20, 2012 | 10:06 PM
JaYZeig's Avatar
mayb just be a valve cover seepin..mine are too
Old Feb 20, 2012 | 10:11 PM
01wss6's Avatar
Its just annoying more then anything. Always seems like something is leaking lmao
Old Feb 22, 2012 | 07:17 PM
ls1wallen's Avatar
try the oil pressure sending unit. it will leak down the back of the block
Old Feb 22, 2012 | 08:20 PM
01wss6's Avatar
I just changed the valve cover gaskets because I felt some oil on the back on the drivers side. I felt around the sending unit and didn't feel anything. Hopefully it was just the valve covers lol. Thanks everyone for the help!!
