coolant leak from back of the engine
What do you guys think might be wrong with it? I was hoping for just a thermostat but the leaking coolant from the rear of the engine makes me think otherwise... Car was running fine up until that night, never getting about the 190-200º mark.
thanks for any help!
Also make sure you use decent intake gaskets so you don't have to do the job twice. I'm more familair with the 3800 which uses a metal core gasket, I'd imagine the 60 degree v6s should be the same. A dab of blue threadlocker on the intake bolts and engine sealant on the corners of the block where the gaskets meet should do ya.
Ultimately though, your just gonna have to fill her up with coolant and rather pressure test it or run it till it leaks and inspect with a flashlight. When the job is done I like to fill the coolant with the upper radiator hose disconnected from the water outlet and fill it though the upper hose until it comes out of the outlet/thermostat housing. Then theres no fighting to get rid of air pockets.
