Best way to protect a splice
I've made some splices under the hood with blinkers and headlights. I was curious what is the best way to protect splice joints from the elements/corrosion?
What I did was cover any exposed copper with solder. I then taped joints with electrical tape and finally put heat shrink around the joint
Soldering the wires together and putting shrink wrap over the wires and splice the best you can, and then maybe some electrical tape over that if you so desire.
Now if I wanted to add the tape I would put it over the heat shrink as the outer layer. But it shouldn't be necessary.
Oops......yes....either or.......
I like butt connectors. Solder can crack over time from vibration.
Yea.....no need for electrical tape at all if you use good shrink wrap. Electrical tape gets all nasty and gooey over time too. Chrysler makes the best shrink wrappers, they have a hardening type of glue inside that makes its like a rock when it cools off..
"Page 19" has the part numbers and wire gauges listed. (You'll have to convert mm2 to gauge at the bottom of the page.)
They work great. I just recently needed some to repair a cut headlight door motor wire.
