odd turn signal problems
Summery : front blinkers don't blink while rears do
With key on but switch off only driver side comes on, with the switch on both light up
Is this pointing toward a fuse or something? I have to admit, I haven't checked anything else as I work nights and its getting close to nap time. But any ideas for me to try tomorrow morning are welcome. After the fuses I am kind of lost on my own though.
Lol, that's the thing, I have never had front turn signals or running lights since I bought the car... I am not even sure if the guys who wired up the old sockets did it right (was a pretty ****-poor job) so I just followed how they were wired, A - brown, B - blue, G - black.
Unless something else had failed (switch or something in the dash) before I bought the car...
Looking for different components of the system to check, not just connections as everything is soldered and am pretty sure making good contact. Back to searching I guess. I did find a thread along time ago about a step-by-step of checking different components but having trouble finding it again...but that other members problem, the rears would stay solid so not sure if it would help anyway.
From that other thread, I do remember something about a box behind the radio about the size of a cigarette box. Not totally sure on what it does though lol.
Yup, I just searched "radio cigarette box" and found the thread I was looking for...weird what you have type in some times lol.
But yeah, when I get home gonna bust out the test light and check power at the blue wires and trace back to the module. I think I might look for my haynes manual and see if I can figure out if the previous owner had the wires going to the correct slots on the socket too...I would think that not a lot of anything would work up front if that was the case though.
Engineers anyhow...hmph
But, it sounds like you do have a bad DRL module. (If your sockets are wired correctly and your flashers are good.) If you end up replacing the DRL module, I'd be interested in acquiring to old/bad one from you so I can dissect it.
That's cool, if I do end up replacing the module, you buy its bus ticket and its yours lol.
I didn't get to test anything yesterday since it was raining and with no garage, I wasn't feeling it...and now the weather says rain for most of he week. Hopefully I'll get to it this weekend.
I have been having a similar issue, I ended up replacing both turn signal housings, both sockets, both bulbs, and the flasher.
I am still having odd behavior, both my DRL turn on when I first start the car up, but sometimes after i use the left turn signal the left DRL will stay off. I can turn on the parking lights and it will light up on the dimmer filament. Even weirder thing is that i can use the right turn singal and then sometimes the left DRL will come back on.
I am thinking my issue must be in the DRL module. I guess i will try replacing it, where would i get one? A junkyard? I guess i could try GM parts direct, anyone know the part number?
So, your parking filament is either burned out in that bulb or you have a wiring/socket problem.
I hope that it is the turn signal switch, cause I found the part # (10407669) and GMpartsdirect wants $220.71 for the DRL module
F'n Sh#t!!
- When its acting up, turn on the hazards and see what happens.
(If I recall correctly, the hazards go through the DRL module but not the turn signal switch.)
For what a module costs, I'd want to do some testing at the DRL module to see what's going on before plunking down the $$$ for a new one. (You might also have luck getting a used module.)
