Part number for catalytic converter
Hey folks,
I have a SLP high flow cats on the car right now, but my passenger side cat has failed. It rattles to no end, sounds like marbles are jumping around in there and is only noticeable at idle, which is annoying and embarrasing at traffic lights.
Anyways, I was wondering what type of common universal replacement cats I should go with. I've read that Magnaflow makes a decent cat. But I don't know he part number for a universal 2.5" diameter cat?
I know cats are expensive, but without breaking the bank are there other good options out there and if you could please provide the part number that would be appreciated!
Thanks guys
Thanks guys
I believe the model no. for the right Magnaflow catalytic converter is 46476. The left is 46477.
Edit: These are the direct fit replacement for the 98-99 camaro. Not the Universal ones.
I should also add that I'm leaning towards metallic substrate cats. The replacement ones need to be similar in size to the SLP high flow cats for easy installation.
Thanks guys
