Squeaky wheel while driving, not while braking
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
While driving at any speed, there is a consistent ring/squeal coming from my rear drivers side wheel. I'm thinking its just a bad bearing, but does it make a difference that it stops the ring whenever I brake? Possibly something to do with the brake? But the brakes do work perfect and are relatively new. Thanks for any input
i think i might be having the same problem, i'm pretty sure mine is the brakes, i might take the pads off and throw some grease on the outsides and the clips where the pads sit on and see if that helps, i've heard this squeek before but it went away
