Sponsored by: CARiD
heater core pipes
Old Mar 21, 2012 | 10:42 PM
99monguse's Avatar
Default heater core pipes
Does anyone know specifically which hose is which connecting to the heater core? My Z28 has no heat, I think the heater core needs backwashed. Anybody know which is the inlet and outlet?
Old Mar 21, 2012 | 10:58 PM
LS6427's Avatar
Just remove both hoses from the water pump and use one of them to blow it out.......
Old Mar 22, 2012 | 08:02 AM
02v8ta's Avatar
That's what I did, that fix only lasted a day mine was so far gone good luck.
Old Mar 22, 2012 | 08:35 AM
Jr.Samples's Avatar
Did you end up changing out the core?
Old Mar 22, 2012 | 12:29 PM
02v8ta's Avatar
Yup, biggest pita but was the 2nd i've done and gets easier everytime. I really hope there's never a 3rd time though.
Old Mar 22, 2012 | 12:39 PM
LS6427's Avatar
So you replaced the core and still have a clog?
If you blow into one of the heater hoses the coolant should shoot right out of the other line end. The ends that attach to the water pump.....
Old Mar 22, 2012 | 12:40 PM
02v8ta's Avatar
No I had to replaced the core after that flush only lasted one day.
Heat worked great until the engine went
Old Mar 22, 2012 | 01:14 PM
Jr.Samples's Avatar
Crap now I know for sure that is what I will have to do. Mine last about a day too. I flushed it three times.
Old Mar 22, 2012 | 03:24 PM
99monguse's Avatar
Can you R/R the heater core through the glovebox opening? I hope the dash don't have to come out like the 3rd gens!
Old Mar 22, 2012 | 03:53 PM
02v8ta's Avatar
Yes you can. I think a good write up i used is on shbox website.
It's all done through the glove box but you have to take the glove box and bottom piece of that out. Easier than the 3rd gens!!! Still took me a night and half day to get through.
Old Mar 24, 2012 | 01:08 PM
99monguse's Avatar
I tried backflushing my heater core because I had NO heat but I can't get the system bled out now. I got the theater core to flow full water bother ways. I disconnected the heater core hoses off the t-stat/waterpump area. I used compressed air and water to flush. I put the hoses back on filled the radiator with 50/50 dexcool and started her up. I can't get the system to flow though. The temp gauge went past 210 and both fans came on but I still had no heat. I don't know if the heater core is no good or not. Could a bad t-stat be the problem? I didn't get really bad stuff out of the heater core when flushed. Should I try replacing the T-stat?
Old Mar 24, 2012 | 03:40 PM
FiredUpZ28's Avatar
Third gens you don't have to take the dash apart, but I will admit the top case bolt is a PITA on those. A little patience and the perfect length extension will do ya.
4th gen heater cores are done through the glove box. Biggest PITA I had when I did my 93 Z was getting the damn hoses off the core under the hood.
If you heat up to 210 and stay there, then no, do not replace the thermostat. Sounds like you rather have an HVAC airflow clog somewhere, or a blend door not swinging to hot. Also could be the core partially clogged. Definately not the thermostat if the engine coolant is heating up as designed and not overheating.
Old Mar 24, 2012 | 03:44 PM
LS6427's Avatar
Hook a water hose to one of the heater lines and flow water through it, don't blow air in there. When you see water coming out the other line its full.
Old Mar 24, 2012 | 05:19 PM
02v8ta's Avatar
Yeah i think running air through there is what is causing this. As said run it all the way through with water then reconnect and follow bleeding procedure
Old Apr 2, 2012 | 08:17 PM
99monguse's Avatar
got it done...man does it pour out heat now! thanx
