Sponsored by: CARiD
Engine sputters during driving
Old Mar 30, 2012 | 11:58 AM
mdz28driver's Avatar
Default Engine sputters during driving
While driving the car it has a sputtering sound and loss of power and when stopped it has a hard idle. My service engine light now comes on. Could this be a problem with the Mass Air Flow Sensor? If anymore information about the car is needed I can provide it. Thanks.
2000 Camaro Z28
130,000 Miles
Old Mar 30, 2012 | 12:03 PM
MZAC's Avatar
Buy some MAF cleaner from the parts store. It comes in a spray can. If no ones done it after 130k it couldn't hurt to try.
Old Mar 30, 2012 | 02:18 PM
Ok thanks I will give it a try. Im guessing replacing it with a new one could help too or maybe its a fuel filter issue?
Old Mar 30, 2012 | 02:23 PM
LS6427's Avatar
MAF should only give you trouble on cold start and then only while at WOT........
Go get a free scan at an auto parts store.....tell us the code number they pull out.
Problems with the 02 sensors are what cause your symptoms.
Old Mar 30, 2012 | 02:47 PM
Ok thanks for the feedback and information.... Much appreciated!!
Old Mar 31, 2012 | 02:27 PM
I got the scan on the car and it came back 'Bank 1 too lean'. What ive read in the forums is the same as the feedback to my thread about the 02 sensor being the issue. There were few post that mentioned the MAF too.
Old Apr 1, 2012 | 02:48 PM
BadBirdie's Avatar
i have the same problem with my 97 trans am 160k. i just replaced one of the front o2 sensors because i had ses codes for it. still have the sputtering. i plan on picking up a new maf from ebay. hopefully this will help but if you find a solution before i do i'd love to hear it.
Old Apr 23, 2012 | 09:28 AM
Ok I had the o2 sensors checked and it wasnt the problem. It was suggested that the MAF might be the issue. I'm going to have it cleaned first to see if that resolves the sputtering issue then have it replaced i f the code comes back again. I was looking at this MAF as a potential replacement:
http://www.lmperformance.com/743/1.html
SLP Performance 23060, SLP Mass Air Flow Sensor, 1998-00 LS-1 High-Flow Camaro V8
Any suggestions or comments? Thanks for the support.
Old May 9, 2012 | 06:15 PM
Ok i thought I would update this thread now that the problem has been solved. So after replacing the O2 sensors, cleaning the MAF and then replacing the MAF becuase it didnt fix the problem, it turns out after a air leak test there was a hose that that came loose under the battery platform. No more sputter, hard idle or computer code.
Old May 10, 2012 | 12:50 PM
Its fixed...see other messages
Old May 10, 2012 | 01:16 PM
Jr.Samples's Avatar
Would you care to share what this hose under the battery was for?
Old May 10, 2012 | 11:52 PM
BadBirdie's Avatar
yes what hose are you talking about? i will look into this tomorrow as i still have this annoying sputter problem
Old May 13, 2012 | 11:22 PM
2500HD6.0's Avatar
I would like to know also
Old May 13, 2012 | 11:43 PM
LS6427's Avatar
A hose under the battery platform....what the hell.....
There's just the radiator overflow tube running into the overflow tank.
Old May 14, 2012 | 08:35 AM
The mechanic said this hose is used to provide extra air to the enigine to keep it cool. It was broken and sucking in bad air causing the o2 sensor to send the code to the computer. I meant to post a picture but did not have a chance to do it. I will post a pic by today or tomorrow.
Old May 14, 2012 | 11:59 AM
LS6427's Avatar
The air pump hose......supposed to pump air into the system on cold start up. Then shut off. For emissions control.
It does run along that side and down under, then over to the drivers side where the air pump is.
BUT...I don't know how it could cause problems because after you start the engine it shuts off and the valve closes. Thats how I thought it worked anyway.....
My pump and air system has been removed. No emissions here.
Old May 14, 2012 | 12:04 PM
Jr.Samples's Avatar
Please don't tell me he changed out your muffler bearings too. Extra air to cool the engine?
There is a lot of us on this site that have the some problem as you looking for a solution. If this was a vacuum leak he should tell you.
Old May 14, 2012 | 12:08 PM
Jr.Samples's Avatar
Unfortunately I have to retain my air pump in Texas and I can tell you none of the hoses are near the battery. The fresh air hose hooks up on the drivers side of the R/A box in front of the pump.
Old May 15, 2012 | 08:48 PM
OK I have a picture of what I am talking about but I dont have a URL address. I can email it to someone for posting. The picture points to the hose that goes down under and just to the right of battery compartment if your facing the car looking down. Let me know if anyone post it in this thread. Let me also say I am no mechanic nor do I have a great knowledge of cars. I know the basics and this is what I was told was causing the sputtering issue.
Old May 15, 2012 | 09:11 PM
LS6427's Avatar
Jeez....you're right. I just looked at some old pictures of my engine bay the day after I picked my car up AFTER my 427ci went in. The shop removed my air pump but they left that one big fat hose....it runs over the drivers fender right along the edge.
I remember calling the shop and asking what the hell that big ugly hose was.....they just said to rip it out....they forgot to........lol
Sorry.............
So what hose could that mechanic be talking about that fixed his issues?????
