headlight motor grinding after closed
Old 04-29-2012, 05:41 PM
firehawkasw's Avatar
Default headlight motor grinding after closed
i have a 2000 pontiac firehawk. recently when i turn my headlights off, the drive side headlight motor makes a buzzing noise after the headlight is closed. also when i lock my car with my key fob the headlights open and then shut. what could cause these issues and how can i fix them.
Old 04-29-2012, 07:02 PM
DisasterFormula's Avatar
Gears stripped out. Time to replace the motor. Get a new unit w/ a lifetime warranty.
Old 04-29-2012, 07:15 PM
Blue2KTA's Avatar
I purchased a motor from AutoZone for $74 w/lifetime warranty. I tried replacing the gear first but that failed a few days later so i went with the motor.
Old 04-29-2012, 07:19 PM
LS6427's Avatar
Do the free fix. Takes 10 minutes. Mine has lasted over 7 years doing it already. Replacing the motor is a bitch.
Old 04-29-2012, 07:26 PM
Blue2KTA's Avatar
I tried the free fix too but i think those metal tabs on the motor just wouldn't hold firm so it stripped out again. Changing the motor is not that bad.
Old 04-29-2012, 07:31 PM
LS6427's Avatar
No need to go into the motor for the free fix though........maybe the tabs didn't hold after going in there.
How long did it take to change a motor?
Old 04-29-2012, 07:43 PM
Blue2KTA's Avatar
Its been a while. I had the motor out twice. Once to swap the gear out then again to swap the motor. 2nd time about 20 minutes tops.
Quick Reply: headlight motor grinding after closed
