Fog lights and switch don't work?
Hi guys, I have a 2001 TA WS6 and I just noticed that the foglight switch isn't illuminated anymore when you switch the foglights on. Also the foglights do not light up anymore. I checked the foglight fuse and didn't see anything there. I didn't notice any other lights out, tailligts still work, so i'm stumped? Maybe a ground problem to the switch? Any help would be appreciated, thank you!
1 Post
All i know is the face panel takes a less than a second to pop off so if it were me i would unplug them, turn the key and hook a volt meter up to the asr and try and get a reading (as it is working i assume) then the fog and see if there is any power going to it. Dunno if it will give you the answer or not but its something at least
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
my fog lights were doing the exact same thing when i bought my car.. i put a new deck in it and the plug to the actual switch was disconnected. plugged it back in and everything works... only take a few minutes to take the dash off
Before buying and replacing anything, I did like one poster suggested and pulled the bezel from around the radio, ASR, Fog Light switch, etc. I unplugged and then replugged the connection off the Fog Lights switch and what do you know, everything is working now. So, it appears to be a connection. Will get back into this on Saturday and see if I can find a loose wire or connection somewhere but for now all is fine.
