Cool air from one side of exhaust?
Is this normal? I noticed it the other day. The pass side exhaust air coming out is not hot at all, even at operating temps. The drivers side is exactly how I would expect it to be.
The car has been sluggish lately and I'm trying to narrow it down a little bit.
Normal LS1 exhaust setup with LT's.
I want to say it's a magnaflow, but I'd have to get under the car to be 100% sure of that.
****Mine is a Magnaflow. Both pipes equally hot as *****.
What jackass system would have two pipes coming out of a muffler and only one pipe spits exhaust out......thats fucked up. Never heard of this.
I guess a cheap one just for looks.....has two pipes, one is a dummy pipe. Maybe????
Thanks for the suggestions, guys. I think the first thing to do is bypass the muffler entirely and see if I notice a change.
I'm going to try restricting the side with the hot air today and see if I get any hot air to the passenger side that way as well.
i dont have different temps on my exhaust tips, they are actually both cool to the touch, even after hours of driving. but i do have more exhaust coming out the drivers side, after i put the magnaflow on. i just think it is the way the muffler splits the exhaust.
think of your exhaust as an electrical system, it takes the least restricted path. for the exhaust to come out the passenger side pipe (when a real muffler is used) then it has to make a u-turn in the muffler just to come out the passenger side. the drivers side has 2 right angles, or a slant that makes it the path with the least resistance, hence why the drivers side is usually hotter, or blows out more exhaust then the passenger side
Thanks for the explanation.
