Sponsored by: CARiD
Turn signals stay solid, and won't turn off on dash
Old May 16, 2012 | 08:51 PM
96reddevil's Avatar
Default Turn signals stay solid, and won't turn off on dash
So I had this problem start recently on my 2001 Trans Am. My right turn signal would work, sometimes. It would either blink really fast or stay solid. This was totally at random. My left turn signal stayed solid no matter what.
Now they both stay solid.
It gets better, one night I decided to take a right turn. Now anytime I turn my lights on, the right turn signal indicator on the dash just stays lit up. The right turn signal isn't lit up on the outside of the car.
My brights also did this. Turned them on, then off, and the bright indicator light stayed dimly light up on my dash, and came and went. Now that the turn signal one is stuck on though, it doesn't stay lit up on the dash.
Any ideas on this? I'm scratching my head on this.
Old May 16, 2012 | 09:37 PM
user 4556884458's Avatar
Have you tried replacing the flasher?
Old May 16, 2012 | 09:59 PM
juSStin4171's Avatar
spend $20.00 and replace ALL 4 turn signal bulbs and fuses before you go searching the electrical system. Hopefully this works.
When I had a bulb out the turn signal indicator on the dash just stayed lit...
Old May 16, 2012 | 11:05 PM
SparkyJJO's Avatar
Bulbs first. Remember that the bulbs are DUAL filament, so just because they glow with parking lights or whatever does not mean the bulbs are OK.
Also check the sockets when checking the bulbs. The fronts tend to get cooked. The sockets are cheap and easy to replace, you don't even need to splice a single wire if you follow some simple directions.
Old May 16, 2012 | 11:06 PM
baalic's Avatar
yup check bulbs then the flasher
/thread LOL
Old May 25, 2012 | 01:51 PM
96reddevil's Avatar
Replaced the bulbs, and nothing. Going to check the flasher this weekend.
Old May 25, 2012 | 02:10 PM
SparkyJJO's Avatar
What condition were the sockets in?
Old May 25, 2012 | 02:20 PM
loyolacub68's Avatar
I have had this problem with bad sockets causing shorts. I had weird problems where my entire instrument cluster would blink when the headlights were on. Check the flasher and then check the condition of the sockets.
Old May 30, 2012 | 09:31 AM
NightHawwk's Avatar
If the bulbs look good I would check the condition of the sockets.
Get any corrosion out of there and check the wire tightness and condition into the socket. Also, your bulb may be loose within the socket. I know that is dumb advice, but it can feel tight and still be loose.
Whenever I have seen the signal on the dash stop blinking (which is constantly, the only problem I have ever had on this car outside of replacing the water pump) it was always the socket's fault.
Old May 31, 2012 | 01:17 PM
White 96LT1's Avatar
i believe it is the multifunction switch sir
Old Nov 20, 2013 | 05:58 AM
WS6andlovingit's Avatar
Ok so I know this is an old thread. But I have a little bit of a different problem. both of my blinkers on the dash stay solid when my lights are on. But they still blink when I use them. They just go back to solid afterwards. The lights are always lite up except when I switch from parking lights to headlights. The bulbs have been replaced and so have the sockets. Any ideas.
Old Feb 6, 2021 | 04:43 PM
PHX SON's Avatar
Default Fix
Flip the light around . it doesn't have a positive negative connect indicators but i flipped mines and the problems were solved
Old Feb 6, 2021 | 11:16 PM
RevGTO's Avatar
Pontiacerator
Since the original post that you quote was from 9 years ago, one hopes he would have found a solution long before you offered your timely advice - although what you are attempting to say is far from clear. Welcome to the Board, but please refrain from digging up and posting on ancient threads.
