Sponsored by: CARiD
E break is out?
Old May 29, 2012 | 06:54 PM
Alberto v05's Avatar
Default E break is out?
How much would it cost to fix an e break on my 1999 z28? Thanks for the help
Old May 29, 2012 | 07:01 PM
projectX's Avatar
If the e-brake cable is broke prob just 20-30 for a shop I would think. But is you need pads I'm not sure. Call around and ask some places locally.
Old May 29, 2012 | 07:04 PM
JUSTINSWS6's Avatar
What do you mean its broke? Handel broke off? Did you cut the emergency brake line?
Thanks, i think its the pads cause it makes a noise when i drive and the e break light is on the cluster and the ABSINOP light is on to
If you pull the hand break car won't stop?
Old May 29, 2012 | 07:13 PM
JUSTINSWS6's Avatar
Will it slow it down any? And do you have a manual?
Old May 30, 2012 | 12:32 AM
No does slow it down at all and yes m6
Old May 30, 2012 | 08:05 AM
JUSTINSWS6's Avatar
Brake padd then because i think thry self adjust so you shouldnt have much slack.
Old May 30, 2012 | 10:39 AM
nomasterase's Avatar
The e brake on these cars does not self adjust they must be periodically adjusted and since most people dont bother they get way out of adjustment. My 02 didnt work when i bought it but once i pulled the rotors they looked brand new. I just adjusted the hell out of em and they worked fine. I believe you have a couple of issues though because the e brake needing adjustment will not cause an abs light. Abs problems will however cause the brake light to illuminate. Id adjust the e brake for sure and then troubleshoot the abs problems
Old May 30, 2012 | 11:01 AM
JUSTINSWS6's Avatar
How do you adjust them take off the brakes then rotors. Is there something under there to adjust?
Old May 30, 2012 | 12:59 PM
Yes there is a star wheel adjuster that sits in the opening of the e brake pad and one end of it is threaded into the housing just use a flathead to turn it a little at a time checking periodically to make sure the rotor still fits. Kinda hard to explain but once you see it its fairly self explanitory
Old May 30, 2012 | 01:35 PM
JUSTINSWS6's Avatar
Is it on both back brakes or just the passenger side?
Old May 30, 2012 | 02:14 PM
Its on both located on the bottom of the e brake backing plate beneath the axle flange
Old May 30, 2012 | 08:52 PM
eb110americana's Avatar
Yeah, there is basically a drum brake inside each of the disk brake rotor hats at the rear. The main difference is that instead of 2 shoes, there is only one giant horseshoe with a gap at the top for the starwheel adjuster and ebrake actuator. The horseshoe flexes to press outward using the two pads, one glued on each side.
Old May 31, 2012 | 07:37 PM
i think its the brake pad too but I'm going to find out soon
Your right, I'm going to get it checked soon
