Passenger side turn signal/DRL not working, but parking lights work?
I have done a search on the board about this and am a little confused. Basically It sounds like it is either something to do with the DRL module behind the radio or flasher/blinkers under the dash. When I turn my parking/headlights on, both amber bulbs light up just fine. When the car is running with the e-brake off, I only have the driver's side DRL on, the passenger one is off. When I try to use my blinkers, the driver's side one works just fine, but the passenger side lights up the green arrow on the dash and just stays lit. I changed the bulb on Saturday so I know it is not the bulb and because it lights up when I turn the parking lights on, it can't be the socket. Does this sound more like a flasher issue under the dash or the DRL module behind the radio? I would like to not have to spend a ton of money on a module for something that isn't even required by law but would like the functionality of my blinker back. Thanks for any help
